13 years agoLogic family for REFCLK
For a new design we need to provide a 150MHz REFCLK to a set of Cyclone V transceivers. The oscillator output will only drive the REFCLK inputs. My question is which logic family I should use for the...
13 years agoI have not tried it in S4 because we use the clkin_50 port on the S4 kit (instead of a refclk port). I have used one of the refclk pins in the A5 kit because I needed to use an SMA driven clock for a while. Never tried either without a transceiver.
The trick with A5 was to use an altclkctrl like so: altclkctrl# ( .clock_type("GLOBAL CLOCK"), .number_of_clocks(1) ) global_pll_ref_clk_inst ( .inclk(REFCLK_P), .outclk(REFCLK_P_BUF) ); and drive REFCLK_P_BUF to the pll input, and REFCLK_P to the transceiver. So I guess it is slightly different than I had originally explained Our Stratix V design does use a PLL output to the transceiver, but thats a whole different beast
