13 years agoLogic family for REFCLK
For a new design we need to provide a 150MHz REFCLK to a set of Cyclone V transceivers. The oscillator output will only drive the REFCLK inputs. My question is which logic family I should use for the...
13 years ago --- Quote Start --- We have successfully driven REFCLK pins to PLLs, generated our frequency for user logic AND Serdes' refclk ports in arria v. I suspect you can do the same for CV. We used lvds or lvpecl. AC coupling's the most important part --- Quote End --- Are you able to use the REFCLK pin if you do not instantiate a SerDes block? I haven't tried this with any of the V series devices, but its not possible with the IV series. The work-around is to create an ALTGX+ALTGX_RECONFIG component, and then essentially not use it (reset it). Cheers, Dave
