16 years agoLock a clock to a 8B10B data stream?
Hi there, I am trying to find a way to synchronize a chain of equipments but don't want to use a dedicated clock network. If I use the transrecivers in Arria II GX to implement GIGE protoc...
16 years ago --- Quote Start --- I merely referred you to the SDI example to illustrate the use of a PFD to lock on external clock to a CDR clock. I did not mean to insinuate that you use a transceiver in SDI mode (even the SDI example doesn't use the transceiver in SDI mode). The principle remains, you need to find some way to lock the external clock to the CDR clock. I have absolutely no experience with GIGE. From what you're saying it sounds like you don't really get a CDR clock from the receiver. Is that true? If so, it seems to me what you'll have to do is actually derive a timing signal from the data rate. This is similar to the way we lock the reference clock in the video world. We use the horizontal sync signal (basically the line rate of the video) and we lock the reference clock using that information. It's very low frequency (about 33.5kHz) compared to the actual clock rate (148.5MHz). Jake --- Quote End --- Hi Jake, Yes, the GIGE mode won't provide CDR clock. When you are talking about deriving a timing signal, are you saying that you have a embedded timming code/packet in your data stream and is send out in a frequency of 33.5KHz? Our frequency is even lower (500Hz-1KHz), but the peak to peak jitter needs to be less than +-10us along the whole line. Thanks, Hua
