Linux not Booting on custom Intel Cyclone V board
Hi Akash,
Im set a call with you today to look your case more closer because at our end we cannot reproduce it
Thank you,
Aliff
Hi, Please find attached the files from the project.
I have compiled BuildingBootloaderCycloneV procedure from scratch
command_list.txt > Contains the list of command executed sequentially.
cv_soc_devkit_ghrd.tar.xz> contains compiled project (for hps_isw_handoff reference, and output files)
linux-bin.zip > The linux-bin resulted after all procedure.
sdcard.tzr.gz > sdcard folder after all procedure.
u-boot.socfpga > u-boot folder after all procedure. (Contains the problematic u-boot-with-spl.sfp, I cloned and checked out v2022.04 as suggested in the guide. )
downloaded_spl_by_jackfrye11.zip > Replacing this "u-boot-with-spl.sfp" with the one I generated myself makes everything work fine and results working linux terminal.
Please use these to recreate the setup. You can burn the sdcard image directly and then you can replace the u-boot-with-spl.sfp file and burn it. It should be working after replacing the u-boot-with-spl.sfp file.
Akash.
- mabdrahi3 years ago
Contributor
Hi Akash
I upload the QSPI image here and sdcard image on the team chat as it too big to upload here.
Thank you,
Aliff
