Linux not Booting on custom Intel Cyclone V board
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- akashgupta3 years ago
I downloaded the "gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu" and declared "export ARCH=arm64" as you suggested but EmbeddedLinuxBeginnerSGuide failed at step 4 (Generating the Preloader) when I entered the make command. It asked to set ARCH=arm, after which it compiled successfully.
Then I cloned "u-boot-socfpga" and checked out rel_socfpga_v2023.01_23.09.02_pr branch. I followed the guide further till step 5 (Configure and Compile U-Boot) and it failed at "make" command. The output is as follows:
UPD include/generated/timestamp_autogenerated.h
ENVC include/generated/env.txt
ENVP include/generated/env.in
ENVT include/generated/environment.h
CC lib/asm-offsets.s
cc1: error: unknown value ‘generic-armv7-a’ for ‘-mtune’
cc1: note: valid arguments are: cortex-a34 cortex-a35 cortex-a53 cortex-a57 cortex-a72 cortex-a73 thunderx thunderxt88p1 thunderxt88 octeontx octeontx81 octeontx83 thunderxt81 thunderxt83 ampere1 emag xgene1 falkor qdf24xx exynos-m1 phecda thunderx2t99p1 vulcan thunderx2t99 cortex-a55 cortex-a75 cortex-a76 cortex-a76ae cortex-a77 cortex-a78 cortex-a78ae cortex-a78c cortex-a65 cortex-a65ae cortex-x1 ares neoverse-n1 neoverse-e1 octeontx2 octeontx2t98 octeontx2t96 octeontx2t93 octeontx2f95 octeontx2f95n octeontx2f95mm a64fx tsv110 thunderx3t110 zeus neoverse-v1 neoverse-512tvb saphira neoverse-n2 cortex-a57.cortex-a53 cortex-a72.cortex-a53 cortex-a73.cortex-a35 cortex-a73.cortex-a53 cortex-a75.cortex-a55 cortex-a76.cortex-a55 cortex-r82 generic
scripts/Makefile.build:147: recipe for target 'lib/asm-offsets.s' failed
make[1]: *** [lib/asm-offsets.s] Error 1
Makefile:1936: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2------------------------------------------------------------------------------------------------------------------------------------------
Please suggest the solution for this.
