17 years agolinear to logarithmic conversion
Hi Guys, I need to implement Linear to Logarithmic conversion using Verilog HDL on overexposed and underexposed pictures through Look Up Tables. But, I lack information on this. Can anyone pr...
17 years ago --- Quote Start --- this is gamma correction, right? the simplest method would be a lookup table for under-exposed and one for over-exposed. for finer tuning you could make more tables or do some kind of interpolation/"fudging" between the tables and a linear curve. --- Quote End --- not exactly but yes it is similar to gamma correction. can you plz explain a bit on the method you told above ...... may with a small example. Thank you
