17 years agolinear to logarithmic conversion
Hi Guys, I need to implement Linear to Logarithmic conversion using Verilog HDL on overexposed and underexposed pictures through Look Up Tables. But, I lack information on this. Can anyone pr...
17 years agoHi,
in my opinion, the first question you should ask yourself is the data format (in linear) and the value range you want to use: e.g: float, double, fixedpoint, signed/unsigned integer, maybe 7 bits integer and so on. If you have determined this very first issue you can go on with e.g. Matlab: you could approximate the log curve you need with lookup tables, raw+fine lookup tables and maybe an interpolation, or an algorithmic approach to approximate the log curve with polynomials. I think there is plenty of information an how to implement this special functionality on the Internet => google, ieee, and so on. Did you take a sight on opencores.org? Maybe there is a finished core available. regards, lestard
