15 years agolimited timing information for Arria II GX
Hello, we are developing an interface board for signal conversion. The incoming signal is sampled at 1.2 GHz (parallel input 14 bit). Two output channels are planned to work at 150 MHz maximu...
15 years ago --- Quote Start --- Do we need to use special definitions for the LVDS-inputs in Quartus? Like superblocks etc.? --- Quote End --- To use I/O pins with LVDS logic levels, you simply need an I/O constraint. However, for reception of Gbps data, you will need to use an LVDS SERDES, or a transceiver channel (available only on GX devices). The two megafunctions are altlvds and altgx. --- Quote Start --- We did not find any hints in documentation. Is the treatment of LDVS inputs similar for Stratix II or completely different? --- Quote End --- Read the digitizer tests document I posted. It shows you the interface requirements for LVDS. LVDS can be configured synchronously, so you will have no problems receiving data. The transceiver serdes lanes are essentially independent, with independent clock recovery, unless your ADC is JEDEC JESD204A/B/C compatible, or has a PRBS generator for lane alignment, you will need to do a lot of work to interface to it. What is the part number you are trying to interface to? --- Quote Start --- Does it make sense to set up a Quartus project for Stratix II in parallel in order to select the FPGA-family later on ? --- Quote End --- Setup a Modelsim simulation to get the interface working, and then a Quartus project to check that timing can be met. Cheers, Dave
