emrahener
3 years agoLimit PCIe speed to Gen2
Hi, I am using Multi Channel DMA Intel® FPGA IP for PCI Express IP on a Agilex device to implement a x16 PCIe EndPoint. Due to some problems I want to change the advertised speed to Gen2 form Gen3....
emrahener
3 years agoHi,
Down training is a capability which every PCIe endpoint must support. My question was related to limiting end point capability to Gen2 (Inside MCDMA PCIe IP) not limiting it from PCIe switch side. Can you please confirm that this is not possible through IP parameters or through modifying generated ip hdl files?
FvM
3 years agoHi,
I'm pretty sure that you can achieve what you want by modifying generated IP files. The feature to limit the maximal speed of a PCIe design has a different purpose, it's there to reduce the interface clock speed or bitwidth when you don't need it. For some reason, the Agilex Gen 4 IP has no feature to configure for below Gen 3 speed. It's probably a matter of reducing the number of alternative core configuration.
If you step through the PCIe simulation, you'll see that communication really starts at Gen 1 speed, going up to the maximal speed supported by both peer. I guess you can simply reduce the advertised speed, but I didn't look into the details.
Frank
Frank
