14 years agoLicense Problem
I have created the encrypted RTL files with the new license but If I replace the earlier license with the new license I am not able to create the SOF(bit) file. Can anyone let me know how to add two license to the Altera tool. Thanks, Vijay K2 Replies
In quartus, you can type both license files in with a ; between them:
IE c:\licenses\license1.dat;c:\licenses\license2.dat This also works with the environment variables LM_LICENSE_FILE etc. Pete - Altera_Forum
I don't know if this solution will resolve your problem or no, but try it. you add under environnement variable two system variable, they have as name : "1-LM_LICENSE_FILE 2-MGLS_LICENSE_FILE" and we write the path of your second license to the above variable. Good luck
