15 years ago'Leaving target processor paused'
When I used the nios-ide (in Ubuntu 10.10), I met a error message below. /opt/altera/10.1sp1/nios2eds/bin/nios2-download: 24: function: not found cd: 55: Illegal option -- eval: 1: search_f...
15 years agoWhen i found this problems with my own designs would be, all the time, that i have surpased the fmax acceptable for the system/FPGA i was running on
Maybe with a time constraining you will fix this. What i have found to work is (obviously) to low the clock speed to slower values. (For example, NIOS II running over 110 MHz in a 7 speed grade Cyclone II would fail to verify; after making the clock 100MHz, it would run find)
