16 years agoLCD TOUCH SCREEN ON NEEK (Nios II Cyclone III edition)
Hi, Some of you may see me as a total noob, but i had 1 year experience in FPGA stuff on a spartan-3 board, exploitted every connector on it. Anyways, i am trying to get accustomed to my new...
16 years agoThe touch screen is hooked up to more then one component in sopc, because you have to control it's functions independently. So you have got one module for showing a picture on the lcd, one interface to access the touch data and an i²c component to set different configuration values. See the LCD-Part as three components.
A good hint is to look into the description from Terasic under http://www.terasic.com/downloads/cd-rom/ you can find ltm and mtdb. There you find all the hints for working with the lcd. The problems I had while working with the neek were, that all data passes the MAX-Chip and because of that you can't normally use a VIP-VCO for Output. You have to use the LCD-Controller Altera provides. There is also a good connector out here in the Forum to get VGA working, see the example here http://www.alteraforum.com/forum/showthread.php?t=6118 That can also be adepted to LCD, perhaps. I hope that helps you a bit. Good luck.
