10 years agoLcd on cyclone iii not displaying and boardtest system.exe could not be found
Good day, Although I am a bit new to altera cyclone iii board but I have been following the instruction in the user manual to configure my board. I realized upon powering the board through the instru...
10 years agoIt sounds like you're doing things right...
--- Quote Start --- perhaps the IP has been assigned --- Quote End --- Perhaps it has. In which case you should be able to find it from your laptop. At a terminal issue an 'arp -a' command. This will list all the IP & MAC addresses connected to your network. Tie up the MAC address of your unit with the IP address listed. For the sake of completeness, I'd also simply try another network cable. Cheers, Alex
