10 years agoLcd on cyclone iii not displaying and boardtest system.exe could not be found
Good day, Although I am a bit new to altera cyclone iii board but I have been following the instruction in the user manual to configure my board. I realized upon powering the board through the instru...
10 years agoHave you connected the board, via the ethernet cable, to a network that will assign it an IP address - i.e. one with a DHCP server? That should assign it an IP address that should (typically) appear on the LCD display. You should the be able to put that IP address into your browser to connect to the board.
The 'BoardTestSystem.exe' is typically in a '..\examples\board_test_system\' folder under the kit's installation folder. If it's not there I suggest you re-download the 'kit installation' and re-install it. Cheers, Alex
