16 years agoLarge fast counters (MaxII)
I'm trying to create a large fast long variable delay. My obvious approach is a 17-bit counter that loads when the trigger arrives and counts down to zero when it stops. Unfortunately even with a -3 ...
16 years agoYou may want to look at this thread: http://www.alteraforum.com/forum/showthread.php?t=22965 (http://www.alteraforum.com/forum/showthread.php?t=22965) message# 4
The example is for a 1 Hz generator divided down from 50 MHz, but it shows how cascading works. If I use a -3 device it runs up to the restricted 304 MHz.
