ManthanWankar
3 years agoKernel restart issue while trying to read or write from the address space of hps2fpga and lwhps2fpga
Currently working on a Arria 10 FPGA and faced this issue while trying to access the gpio connected on the lwhps to fpga bridge but when i try to access the lwhps2fpgs address section(0xff200000) my...
aikeu
3 years agoHi ManthanWankar,
Is there any error return when execute bridge enable?
If there is no error then when peform md 0xff200000, the system will reset?
Are you using the GSRD from building bootloader to test before any modification?
I can try to test the GSRD on my side but will need some time to do that.
Aik Eu
- ManthanWankar3 years ago
no error returned while bridge enable
yes it will give a data abort error and the system will reset.
yes i am using the GSRD only have changed the memory size from 1GB to 2GB else every thing is the same
the default device tree does not have fpga bridges in it's device tree node so have added those.
also using quartus pro 22.4 instead of quartus pro 23.2
