17 years agokeep program after powerdown
How do I keep the same program loaded in a CPLD after a power down without having to reconfigure. Do I need to use a configuration EPROM such as an EPC1? If so, how do I program an EPC1?
17 years agoHi,
Are you referring to CPLD's i.e. Altera MAX devices or FPGA's (Stratix, Cyclone etc)? CPLD's maintain their configuration during power off and do not require a config device. FPGAs are SRAM based and need a Config device. Different families and size of devices require different config devices so look at the literature for the parts you are interested in. Config devices can be programmed in-situ with a JTAG cable to your PC or via s/w running on a control processor on your design. All the answers are here... http://www.altera.com/support/devices/configuration/cfg-index.html Good luck
