8 years agoJTAG timing constraints
Hi, Over the years my company has made many Altera FPGA designs, and for a long time the way-of-work for JTAG constraints remained undefined and of little consequence. Then for a couple Arria ...
8 years ago@Leonardo:
The latest cookbook example for JTAG is lot more extensive than your example. It also includes fitter-specific constraints, implying these *do* have effect? --- Quote Start --- if { $use_fitter_specific_constraint && [string equal quartus_fit $::TimeQuestInfo(nameofexecutable)] } { # Define a different set of timing spec to influence place-and-route # result in the jtag clock domain. The slacks outside of FPGA are # maximized. } --- Quote End --- Our JTAG hardware routing is nothing special, and we always use USB Blaster I which only supports 6 MHz. Considering each clock cycle is a whopping 166 ns, I find it hard to believe that JTAG constraints could pose an issue at all, but they do. I conclude then that the constraints (sometimes adversely) affect the FPGA logic.
