17 years agoJtag problem
Here we go again! For a very simple project i used a MAX7032S. Suggested pullup an pulldown are used at jtag pins, connections kept as short as possible and large ground path as well. Only way...
17 years agoHave you done some soldering rework on the two bad boards? It is a very typical situation that after a soldering rework, if the soldering paste has not correctly washed with a solvent, the JTAG port suffers from parasitic low impedance paths which destroy the signals.
