17 years agoJtag problem
Here we go again! For a very simple project i used a MAX7032S. Suggested pullup an pulldown are used at jtag pins, connections kept as short as possible and large ground path as well. Only way...
17 years agoWhat exactly do you mean when you say that at the beginning the JTAG interface seems working? Do you perform normal operations initially and then suddenly you have a failure?
What board is that? An Altera evaluation board or a custom board?
