13 years agoJTAG design for cyclone iii ep3c5E144
Dear all, This is my first attempt to create a FPGA board. My board only uses JTAG (no AS) for programming. I have attached the schematic and board in the *.zip file. Would you please having a ...
13 years agonCE function is related to the AS/AP configuration interface. It's purpose is to tristate the FPGA signals driving a configuraton memory. It can be tied to GND if no external access to a configuration memory (through AS programming connector or embedded processor) is intended.
Your design is missing 1.2V and 2.5V supplies. Both are required by the Cyclone 3 FPGA, read the device manual. Furthermore bypass capacitors at all power supply pins are strongly suggested. I would always add a serial configuration flash (EPCS or compatible) to the design. It can be programmed through JTAG indirect method. A single clock input is sufficient for most basic designs.
