8 years agoJTAG connection issue
Hi all, I have a board that configured the Cyclone 4 E device JTAG signals with 2.5V with 100 ohm series resistor on all signals and TMS, TDI pulled up to 2.5V through 2.2k resistors. I ob...
8 years agoYes, this sounds exactly like a signal integrity issue. The newer Altera USB-Blaster has a flexi-rigid cable to the target instead of standard ribbon cable, like the Terasic Blaster. That is to combat exactly this issue.
I'd remove the 100R resistors - short them out. You might consider keeping a smaller value on TCK. The TDO should certainly improve without a series termination - the TDO buffer out of the FPGA is not very strong. The voltage levels you refer to being a little low could easily be your oscilloscope and probing (perhaps) not being up to the job. However, I wouldn't worry about that for the minute. Do you have particularly long JTGA traces on your board? Try changing the resistors and see if that improves things. Cheers, Alex
