13 years ago
JTAG Chain problem - no device detected (Tried with multiple boards)
Hi everyone,
I'm doing some work with custom cyclone III boards
and am in the process of trying to program the device
using a JTAG port and a USB Blaster cable. The boards
were used last year and successfully programmed.
This is the first time I am working with the boards (we
have about 6 of them) and I'm having no luck. I don't
think it is a hardware problem at the board level as
I receive the error
Error: Can't access JTAG chain
Error: No device detected
No matter which board I try.
We currently only have one USB Blaster, but I'm looking
into getting another to see if that is where the fault is.
I am also installing quartus on a completely different
system, Ubuntu 12 32-bit, as opposed to the windows 7
64-bit system it is not working on, to see if that is where
the problem is. In the mean time I was hoping to find out
other possible places the problem could exist.
Background information
USB Blaster is visible to the computer and altera programmer
shows up as "device is working properly" in the device manager.
USB Blaster has power LED active and when attempting to
program, the other LED becomes active as well.
The board has power and the power LED is active.
I'm not sure where else the problem could be except at
the USB Blaster cable level or the computer setup. I don't
suspect it is a fault with the board hardware as the same
problem occurs with multiple boards and the boards have
been successfully programmed before.
Are there any other possible causes that I am missing?
Any suggestions how I should proceed?
Mat.
    --- Quote Start ---
    Thanks for all your help Wombat,
    turns out the problem was all bad communication.
    It was written in the documentation to flash via JTAG
    however after chasing up some previous members of the team
    it turns out the board was set up for active serial programming.
    Mat.
    --- Quote End ---
    i am having the same problem can u please share the document link .
    thanks in advance
    We had a problem with JTAG and it was the BGA package not soldered on properly, which I said was the problem initially, but got fierce blowback from the guy who soldered it on. What a pain. Altera's diagrams are indeed correct in this regard.
