14 years agoJTAG chain debugger tools scripts & JTAG clock management
Hi everyone, For a design tests, I'm planning to implement this design to a Cyclone II FPGA (integrated to a DE1 board). I then would like to apply stimuli on DUT inputs via the JTAG chain an...
14 years ago --- Quote Start --- Thank you for the information, it can be a useful feature. However I'm not using any Avalon bus as my system validates different modules which will be integrated to an ASIC. --- Quote End --- You've got a couple of options; 1) Build an Avalon bridge to whatever bus protocol your ASIC works from. Ignore the fact that this example uses the Avalon protocol, use it to design a JTAG-to-programmable I/O. The main advantage is that the logic is debugged, working, and supported by Altera. 2) Use the low-level JTAG interface to design your own test logic. See these two documents: http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf) http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip http://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/vjtag.pdf) The first shows the protocol of the JTAG-to-Avalon-ST component, from which you could construct whatever bridge you like. The second shows the lowest-level JTAG interface. The zip file contains Modelsim simulations, so you can use those to develop your debug logic and decide what interface you like. Cheers, Dave
