Hi Serge93,
Could you try one more step?;Try configure the smartVID setting first before you can connect to the board via JTAG. Please refer to this link to connect your board via JTAG: 3.6. The Required SmartVID QSF Assignments to Compile a Design
Fakhrul
Hello Fakhrul,
I guess my Smart VID was already ok for my board.
Please check the attached image.
Thanks for help.
Serge
- FakhrulA_altera2 months ago
Hi Serge,
Could you check if your QSF assignment is set as shown below?
set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name USE_PWRMGT_SCL SDM_IO0
set_global_assignment -name USE_PWRMGT_SDA SDM_IO12
set_global_assignment -name USE_CONF_DONE SDM_IO16
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "100 KHZ"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE OTHER
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS 47
set_global_assignment -name PWRMGT_SLAVE_DEVICE1_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE2_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE3_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE4_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE5_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE6_ADDRESS 00
set_global_assignment -name PWRMGT_SLAVE_DEVICE7_ADDRESS 00
set_global_assignment -name PWRMGT_TRANSLATED_VOLTAGE_VALUE_UNIT VOLTS
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE OFF
Fakhrul- Serge932 months ago
Hello Fakhrul,
The check is ok.
Thanks for help.
Serge- FakhrulA_altera2 months ago
Thanks Serge,
I will submit a ticket on your behalf to proceed with the RMA and will update you any updates.
Fakhrul
