17 years ago
Jrunner + Serial Flash Loader (SFL) + EPCS4 [How to programm EPCS without Quartus II]
I'd like to adapt Jrunner to work with Serial Flash Loader. I've integrated SFL megafunction into my design and it works great. When I click auto detect in quartus II programmer it detects Cyclone II and EPCS4 which is good. How does it detect EPCS4? I'd like to modify Jrunner so I can read sillicon ID of EPCS4, erase or programm it. Reading sillicon ID is the simplest operation so I will implement it first.
I've read AN39 (JTAG in Altera Devices) but there is nothing about "talking" with secondary device (EPCS) by SFL. I don't know which JTAG instruction mode I should use. I just only know that read sillicon ID operation code is "1010 1011" for EPCS devices and that the answer should be 0x12 for EPCS4.
Do you have any suggestions?
    When you generate de .rbf file in Quartus, there is an option called "Mode Liste", where you can decide between Fast Parallel, Serial, etc. Do you remember which option you used? And actually, I don't understand this options: we are using JTAG, no one of this options which are propietaries from Altera, and it doesn appear a JTAG option in this list....
