Norick
7 years agoJitter performance due to non-dedicated routing?!
Hello I am using: Quartus 18.0 Max10 Now I get following warning message: Warning (15064): PLL "... output port clk[0] feeds output pin "ADC_CLK~output" via non-dedicated routing -- jitter per...
- 7 years ago
I'm only assuming the "two issues" are true for your design. Without knowing more of your device/pinout I can't comment.
Regardless of that, I'd change it to use a single PLL using two clock outputs, ensuring you use the appropriate FPGA pin, associated with the right PLL, for ADC_CLK.
Cheers,
Alex
a_x_h_75
Contributor
7 years agoI'm only assuming the "two issues" are true for your design. Without knowing more of your device/pinout I can't comment.
Cheers,
Alex
