MYoha
6 years agoJAMPLAYER for ARM
We have a customer running into jamplayer error ('syntax error') message.
They are running it after porting to ARMv8 (64-bit).
Error message attached.
Are there additional steps required ...
JohnT_Altera
6 years agoHi,
It should be similar but you can try to see if you are observing the issue. Are you using blaster to configure the device or Arm GPIO to directly configure it? If you are using USB-Blaster then you can try using Quartus Programmer Standalone Toolkit.
MYoha
6 years agoHi,
The customer is trying to configure through ARM GPIO
