11 years agoIt is worse to assign clock on different bank or on non-clock input pin?
Hi, I need to get four RGMII interfaces on HSMC attachment board and I have found that only 3 clock inputs are on the same bank as data lines. RGMII is only 125MHz so there is possibility tha...
11 years agoI would recommend using option# 2 which would have higher chance to pass Fitter compilation. You can create a simple test design and let it run through Quartus II compilation to see if there is any error or critical warning to further verify the implementation.
