Issues with updating Arria10 PAC for AFU
- 5 years ago
I was finally able to update this using super-rsu after completely shutting off power to the server (cold reboot):
[]$ super-rsu --log-level trace /usr/share/opae/a10-gx-pac/super-rsu/base/rsu-09c4.json [2020-12-28 16:33:37,086] [DEBUG ] [MainThread ] - found fpga objects: ['/sys/class/fpga/intel-fpga-dev.0'] [2020-12-28 16:33:37,088] [DEBUG ] [MainThread ] - found device at 0000:3d:00.0 -tree is [pci_address(0000:3a:00.0), pci_id(0x8086, 0x2030)] [pci_address(0000:3b:00.0), pci_id(0x10b5, 0x8747)] [pci_address(0000:3c:08.0), pci_id(0x10b5, 0x8747)] [pci_address(0000:3d:00.0), pci_id(0x8086, 0x09c4)] [pci_address(0000:3c:10.0), pci_id(0x10b5, 0x8747)] [pci_address(0000:3e:00.0), pci_id(0x198a, 0x385c)] [2020-12-28 16:33:37,096] [WARNING ] [MainThread ] - Update starting. Please do not interrupt. [2020-12-28 16:33:37,097] [DEBUG ] [MainThread ] - [3d:00.0] version (0x0124000200000367) up to date for sr [2020-12-28 16:33:37,098] [DEBUG ] [MainThread ] - bmc_fw is being force flashed [2020-12-28 16:33:37,098] [DEBUG ] [MainThread ] - bmc_fw versions not equal (system:0x0000000000026889 != manifest:0x0000000000026895) [2020-12-28 16:33:37,098] [DEBUG ] [MainThread ] - bmc_fw versions not equal (system:0x0000000000026889 != manifest:0x0000000000026895) [2020-12-28 16:33:37,099] [DEBUG ] [MainThread ] - [3d:00.0] update timeout set to: 1200.0 [2020-12-28 16:33:37,099] [DEBUG ] [3d:00.0 ] - update of board at [pci_address(0000:3d:00.0), pci_id(0x8086, 0x09c4)] started [2020-12-28 16:33:37,099] [DEBUG ] [MainThread ] - max timeout set to: 0:20:00 [2020-12-28 16:33:37,100] [DEBUG ] [3d:00.0 ] - starting task: fpgasupdate /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4_bootloader-26895-fw_Release.bin 0000:3d:00.0 [2020-12-28 16:33:37,222] [WARNING ] Update starting. Please do not interrupt. [2020-12-28 16:33:37,223] [INFO ] updating from file /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4_bootloader-26895-fw_Release.bin with size 38016 [2020-12-28 16:33:37,331] [INFO ] writing to staging area [2020-12-28 16:34:36,173] [DEBUG ] [MainThread ] - waiting (0:19:00.927721) for threads: 3d:00.0 [2020-12-28 16:34:36,674] [DEBUG ] [MainThread ] - waiting (0:19:00.426487) for threads: 3d:00.0 (100%) [____________________] [38016/38016 bytes][Time:0:01:34.404933] [2020-12-28 16:35:11,747] [INFO ] applying update to 0000:3d:00.0 (100%) [____________________][Time:0:00:08.010363] [2020-12-28 16:35:19,757] [INFO ] update of 0000:3d:00.0 complete [2020-12-28 16:35:19,758] [INFO ] Secure update OK [2020-12-28 16:35:19,758] [INFO ] Total time: 0:01:42.536032 [2020-12-28 16:35:19,809] [DEBUG ] [3d:00.0 ] - task completed in 0:01:42.707920 [2020-12-28 16:35:19,809] [DEBUG ] [3d:00.0 ] - starting task: fpgasupdate /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4-26895-fw_Release.bin 0000:3d:00.0 [2020-12-28 16:35:19,932] [WARNING ] Update starting. Please do not interrupt. [2020-12-28 16:35:19,934] [INFO ] updating from file /usr/share/opae/a10-gx-pac/super-rsu/base/a10sa4-26895-fw_Release.bin with size 244864 [2020-12-28 16:35:20,039] [INFO ] writing to staging area (100%) [____________________] [244864/244864 bytes][Time:0:00:01.575939] [2020-12-28 16:35:21,626] [INFO ] applying update to 0000:3d:00.0 [2020-12-28 16:35:36,247] [DEBUG ] [MainThread ] - waiting (0:18:00.853465) for threads: 3d:00.0 [2020-12-28 16:35:36,748] [DEBUG ] [MainThread ] - waiting (0:18:00.352268) for threads: 3d:00.0 (100%) [____________________][Time:0:00:43.055355] [2020-12-28 16:36:04,681] [INFO ] update of 0000:3d:00.0 complete [2020-12-28 16:36:04,682] [INFO ] Secure update OK [2020-12-28 16:36:04,682] [INFO ] Total time: 0:00:44.749368 [2020-12-28 16:36:04,702] [DEBUG ] [3d:00.0 ] - task completed in 0:00:44.892688 [2020-12-28 16:36:05,283] [INFO ] [MainThread ] - 1 board updated. A power-cycle is required. [2020-12-28 16:36:05,284] [INFO ] [MainThread ] - super_rsu.pyc completed in: 0:02:28.187105 [2020-12-28 16:36:05,284] [INFO ] [MainThread ] - super-rsu exiting with code '0' #Check the fme with fpgainfo to make sure it is updated []$ fpgainfo fme Board Management Controller, microcontroller FW version 26895 Last Power Down Cause: POK_CORE Last Reset Cause: None //****** FME ******// Object Id : 0xEB00000 PCIe s:b:d:f : 0000:3D:00:0 Device Id : 0x09C4 Socket Id : 0x00 Ports Num : 01 Bitstream Id : 0x124000200000367 Bitstream Version : 1.2.4 Pr Interface Id : 38d782e3-b612-5343-b934-2433e348ac4c Boot Page : userI'm not totally sure why the fpga-otsu command would not originally complete (and then finally completed), but my best guess is that using a slightly different kernel minor version or that restarting the server with cold reboot (powering off the server) helps to reinitialize the FPGA state and devices under /sys/. Note that warm reboots (normal power-cycle) may be causing some weirdness with the FPGA device initialization, which is why I've recommended cold reboots (turning off power completely for 20-30 seconds).
For the original issue with super-rsu my suggested solution is the following:
1) Follow the instructions to run fpga-otsu on pg. 40 of the AFU Quick Start Guide. If it fails, power the server off completely for ~30 seconds (cold reboot), power on, initialize the AFU devstack (`. /opt/inteldevstack/init_env.sh`) and rerun the command until it succeeds.
2) Once fpga-otsu completes, perform a cold reboot again. This command should probably replace Step 2 on pg. 41 that originally suggests to "2. Power cycle the server." which can mean either a warm or cold reboot.
3) Check that the ifpga_sec_mgr module is properly loaded correctly and that the ifpga_sec_mgr device exists. If it does not exist, try a cold reboot and check each time after initializing the AFU devstack.
`ls /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/ifpga_sec_mgr/
ifpga_sec0`4) If this device exists, then the super-rsu command should complete successfully (or at least fail elsewhere).
Could you try to remove 1 of the board and make sure that the board firmware is able to update to 1.2.1 correctly?
Hi John,
I should clarify that we have 2x Arria10 PAC cards but they are in two separate servers both running the same version of Linux. I'm not sure that removing one card would change anything here since there is only one card in each server. Is there something else I could try, either just using the 1.2.0 firmware and an older stack or using a latest Github release, if available?
For more information - one card finishes the initial fpgaotsu update but fails at the super-rsu command (as in this post). The second card in a separate server won't even finish the initial fpgaotsu update process. I tried posting on the OPAE Github for this second issue (link here) but have not heard back yet.
[]$ sudo fpgaotsu /usr/share/opae/a10-gx-pac/fpgaotsu/base/otsu-09C4.json [2020-09-02 21:12:14,385] [INFO ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:01:00.0 is not secure. [2020-09-02 21:12:14,393] [WARNING ] [MainThread] Update starting. Please do not interrupt. [2020-09-02 21:12:14,394] [INFO ] [0000:01:00.0] Updating Intel PAC with Intel Arria 10 GX FPGA : 0000:01:00.0 [2020-09-02 21:12:14,396] [INFO ] [0000:01:00.0] Erasing flash@0x7fd0000 for 196608 bytes [2020-09-02 21:12:14,591] [INFO ] [0000:01:00.0] Writing flash@0x7ff0000 for 104 bytes (RushCreek_Release_key_blk2) (100%) [████████████████████] [104/104 bytes][Time:0:00:00.000068] [2020-09-02 21:12:14,593] [INFO ] [0000:01:00.0] Reading flash@0x7ff0000 for 104 bytes for verification (100%) [████████████████████] [104/104 bytes][Time:0:00:00.006021] [2020-09-02 21:12:14,600] [INFO ] [0000:01:00.0] Verified flash@0x7ff0000 for 104 bytes (RushCreek_Release_key_blk2) [2020-09-02 21:12:14,600] [INFO ] [0000:01:00.0] Erasing flash@0x1800000 for 41943040 bytes [2020-09-02 21:12:54,742] [INFO ] [0000:01:00.0] Writing flash@0x1800000 for 41943040 bytes (dcp_1_2_1_rot_reversed.rpd) (100%) [████████████████████] [41943040/41943040 bytes][Time:0:01:06.238681] [2020-09-02 21:14:01,045] [INFO ] [0000:01:00.0] Reading flash@0x1800000 for 41943040 bytes for verification (100%) [████████████████████] [41943040/41943040 bytes][Time:0:00:58.330970] [2020-09-02 21:14:59,404] [INFO ] [MainThread] Total time: 0:02:45.010901 [2020-09-02 21:14:59,405] [ERROR ] [MainThread] Intel PAC with Intel Arria 10 GX FPGA 0000:01:00.0: Verification of dcp_1_2_1_rot_reversed.rpd @0x25165824 failed [2020-09-02 21:14:59,405] [ERROR ] [MainThread] One-Time Secure Update failed
- jyoung6 years ago
Hi John,
As I mentioned above we only have one 1 card in the machine, and it is running with the listed supported OS of Ubuntu 18.04.
Do you have any other suggestions we could try? For example, should we just use the 1.2.0 acceleration stack until Intel releases a better fix? Alternatively, can we use the 2.0.1 stack for the D5005 PAC to see if that works appropriately?
Jeff
