CAlex
Contributor
3 years agoIssues on <alt_interrupt.h> header file
I include the <alt_interrupt.h> in order to use the interrupt on HPS form fpga,
I got the following error
which I believe from this block in <alt_interrupt.h>:
Could you pl...
aikeu
3 years agoHi CAlex,
I was looking into this documention previously which relates to some related software tools involved in the steps:
https://github.com/arktur04/cyclone-v-baremetal
Anyway I suggest you can follow the newer build steps in refering to the cyclone V timer example which consider the alt_interrupt.h (Running Cyclone V Timer Example):
https://www.rocketboards.org/foswiki/Documentation/HWLib
The example code as below:
Aik Eu
- CAlex3 years ago
Contributor
I read throught the link you gave and tried a little but it seems didn't work on Liunx.
The example you gave I assume is with the GHRD yet can't work as well.
Could you provide timer interrupt examples work on linux?
I didn't find any on intenet.
Thank you for help
reguards.
