Wiede
1 year agoIssue with Pixel Buffer DMA AVMM -> AXI connection on DE25-Standard (Agilex5)
I’m working with the DE25-Standard board from Terasic, which has an Agilex5 FPGA (A5ED013BB32AE4SR1). In Quartus 25.1.1 Platform Designer, I’m using a Nios V/g CPU with the standard on-chip memory a...
ShengN_altera
1 year agoHi,
Understood that since there's no writeresponse valid signal so the “pending write transactions” cannot be set.
The DDR4 AXI is connected to multiple master which are NIOS V and DMA controller
Could you try using the Fixed Priority Arbitration check this https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/designate-a-slave-to-use-fixed-priority.html
May I know this connection you're refering to design example?
Sheng
