AdamT
2 years agoIssue with MAX10 FPGA ADC
We appear to have an issue with the ADC on the MAX 10 ADC. The ADC inputs appear to be feeding current onto the signal being measured. We are using the ADC to measure the voltage of a number of poten...
AqidAyman_Altera
2 years agoI am not aware if those pins are enabled internal weak pull-up as default setting. If based on the link below, it mentioned all I/O pins have option to enable the weak pull-up resistor.
