Issue with Downloading .sof file to Agilex Device Via Quartus
I have successfully build a .sof file and attempted to download it to Agilex device using Quartus. However, I have the following error message
Error [213002]: programming option is illegal.
after reviewing the Intel Agilex document and I found out the Agilex device includes a Secure Device Manger. Could this be influencing the error?
Is any workaround solution available to successfully download the file?
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- NurAiman_M_Intel
Any further information needed for this case? Else, I will proceed to close this case for now.
Aiman
- NurAiman_M_Intel
Your case is similar to this forum case, the difference is only the device.
For Agilex 7, you may refer below:
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDDEVAGF027
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7#Boot_from_QSPI
Let me know if you have any questions.
Aiman
- NurAiman_M_Intel
You are using HPS right? Please provide us your smartVID setting. You can find it in Quartus.
Aiman
- WOLVS2
HPS is used in the deign. The constraint file can be found in the attachment.
- NurAiman_M_Intel
Do you have any update for this case? Any further information needed?
Aiman
- WOLVS2
Hi Aiman,
Thank you for looking into this.
I attempted to recompile the .sof file using the updated Quartus 24.1, but the errors have persisted.
Please advise on the next steps.
- NurAiman_M_Intel
It might be that the Quartus Prime software cannot use this file because the file is corrupted or incomplete.
Can you try to regenerate the file and make sure the regenerated file is not corrupted or incomplete.
Aiman
- sstrell
Which device? What version and edition of Quartus (presuming Pro)? Does your design include any IP that you haven't licensed?
- NurAiman_M_Intel
-Can you provide the screenshot of the error?
-What type of Agilex did was used? Please provide the OPN number.
-What is the Quartus version?
Aiman
- WOLVS2
Hi Aiman,
Thank you for looking into this. Here are my responses:
Here is screenshot of the error.
The target device is agfb027r24c2e2vr2.
The version is 23.04
