ISP1761 and Altera DMA
Hi all,
I use ISP1761 USB Controller for PC <--> FPGA communication
So to adapt USB PIO to Avalon interface :
--! SO_ISP1761 entity brief description
entity SO_ISP1761 is port(
-- Avalon interface
av_cs_n : in std_logic; --! chip select from avalon interface
av_write_n : in std_logic; --! write enable from avalon interface
av_read_n : in std_logic; --! read enable from avalon interface
av_address : in std_logic_vector(17 downto 0); --! address from avalon interface
av_writedata : in std_logic_vector(31 downto 0); --! data to usb
av_readdata : out std_logic_vector(31 downto 0); --! data from usb
av_hc_irq : out std_logic; --! Host Controller to avalon interface irq
av_dc_irq : out std_logic; --! Peripheral Controller to avalon interface irq
av_dc_readdata : out std_logic_vector(31 downto 0); --! dummy for irq slave
-- interface with IPS1761 module
dc_irq : in std_logic; --! Peripheral Controller interrupt signal
hc_irq : in std_logic; --! Host Controller interrupt signal
dc_dreq : in std_logic; --! DMA controller request for the Peripheral Controller
hc_dreq : in std_logic; --! DMA controller request for Host Controller
usb_d : inout std_logic_vector(31 downto 0); --! data bidirectional pads
dc_dack : out std_logic; --! Peripheral Controller DMA request acknowledgment
hc_dack : out std_logic; --! Host Controller DMA request acknowledgment
usb_a : out std_logic_vector(17 downto 1); --! address
usb_cs_n : out std_logic; --! chip select assertion indicates the ISP1761 being accessed; active LOW
usb_rd_n : out std_logic; --! read enable; active LOW
usb_wr_n : out std_logic --! write enable; active LOW
end entity SO_ISP1761;
--! @brief Architure definition
--! Adapt extern usb interface to avalon interface
architecture rtl of SO_ISP1761 is
begin
usb_a <= av_address(17 downto 1);
usb_d <= av_writedata when av_cs_n = '0' and av_read_n ='1'
else (others => 'Z') ;
av_readdata <= usb_d when av_cs_n = '0' and av_read_n ='0' and av_write_n ='1'
usb_cs_n <= av_cs_n;
usb_wr_n <= av_write_n;
usb_rd_n <= av_read_n;
av_hc_irq <= hc_irq;
av_dc_irq <= dc_irq;
end architecture rtl;
TCL file :
