14 years agois VHDL unsafe with state machine?
Typical VHDL state machine is to define a type that consist of states, then use that type in a signal. But if someone (not me, no way! ;-)) forget to put a reset state, the state machine continues to...
14 years agoHi, I think both replies miss the point that there is discrepancy of hardware behavior and RTL functional simulation. If one assume this only relate to flops that always reset to some value as I discussed in original post, this is not a problem. But the real flop in ASIC or may not behave this way. Correct behavior is undefined output from flops (sometimes 0, sometime 1, never known a priori). Therefore, coding this way with left most entry as default state does not address the issue of undefined output from real flop causing the post place and route and hardware behavior to not match RTL functional.
Granted, one can say this is reset bug, so that should be fixed. But functional simulation will not catch this kind of bug when all states are defined. I supposed one can go a step further and define and undefined state as left most in type declaration just to catch not properly resetted state machine, but that's so kludgy... As for HW, I was testing an FPGA hardware in lab long ago, and it would only work after dozen or so power cycles. Now I think of it, I suspect the guy who did RTL did not reset his state machine written in VHDL.
