15 years agois this possible to program elf file in flash without souce code
hello all, it this possible to program flash used for storing elf file in nios ii without main source code.that mean i want give only executable file not souce code for programming.
15 years agoelf2flash and nios2-flash-programmer are the command line tools that you need to become familiar with. They are both covered, adequately, in the nios ii flash programmer user guide (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf).
There are also analogous commands for creating "flash" files (SRECs) for binary files (bin2flash) and SOFs (sof2flash). Cheers, slacker
