is there the same silicon chip used in different housings
- 2 years ago
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
Hi there,
Apologies for the confusion. Due to Ethan's job change, I'm stepping in to address your concerns. First and foremost, let me clarify: are you looking to interchange between different packages of the same device? Are you seeking a pin-to-pin reference?
If I understand correctly, unfortunately, we do not have similar documentation or references, as this idea is rather unconventional. It's more common to migrate between devices of the same series but different performances within the same package, and we do have documentation for such cases.
Additionally, I'd like to clarify the differences you mentioned between the configuration files you've generated. Could you please specify in which aspects these differences are reflected? If you could provide information and screenshots in this regard, perhaps we can discuss further.
Best regards, WZ
