is there the same silicon chip used in different housings
- 2 years ago
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
As far as I know, the Jtag could get a jtag id while auto detecting, and the jtag id is unique for each package.
What is the specific OPN for the two devices(QFP and BGA)?
You could check the jtag id in the "pgm_parts.txt" located in Quartus install path.
./quartus/bin64
Via Jtag, you could check the header of the configuration file pof, sof or jic.
I think you could try to configure with rbf or rpd file if the header is the gate.
Ethan
this is the extract from the pgm_parts.txt file from Quartus 9.0 for the device:
EPF10K100A 88 20 18 15 0 EPF10K100A 0 0 10 0 1 0x001000DD 0xFFFFFFFF 0 155/000 0
EPF10K100AB356 88 20 18 1 356 EPF10K100A 0 0 10 0 1 0x001000DD 0xFFFFFFFF 0 155/000 0
EPF10K100AB600 88 20 18 1 600 EPF10K100A 0 0 10 0 1 0x001000DD 0xFFFFFFFF 0 155/000 0
EPF10K100AF484 88 20 18 4 484 EPF10K100A 0 0 10 0 1 0x001000DD 0xFFFFFFFF 0 155/000 0
EPF10K100AR240 88 20 18 12 240 EPF10K100A 0 0 10 0 1 0x001000DD 0xFFFFFFFF 0 155/000 0
I assume the 0x001000DD is the device ID, i.e. identical for all housings...
The POF on the other hand includes in the header complete device ID (with housing and speed grade).
The two devices are in detail the (currently used) EPF10K100ARI240-3 and the (intended) EPF10K100AFI484-3.
