CS72
2 years agois there the same silicon chip used in different housings
Hi, if one can buy the same size in different housings, will the chip be the same for the housing with lowest and highest Pin Count? Would e.g. same silicon chip being housed in 484Pin BGA (i.e. h...
- 2 years ago
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
CS72
2 years agoHi,
I used the BSDL files for the different housings to generate a cross-reference, changed the target device and edited the Pin Assigments. I would have expected to get the same configuration file by this, but it's different.
Is the device ID coded within the POF File? I assume not, if the same chip is used... Would the BGA be programmable with the unchanged QFP configuration file?
