is there the same silicon chip used in different housings
- 2 years ago
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
Answer is yes.
What is the question behind? What do you want to achieve?
thanks for the quick response.
The Idea behind is to minimize (to zero?) the changes in the configuration data when switiching the housing (due to availability from the currently used QFP to an BGA) by assigning the matching BGA pin to the signal currently assigned to the 240'er housing pins.
Assignment of the BGA Pin being bonded to the IO cell used for the signal with the QFP should (imho) result in same configuration data, as the silicon is identical and thus the IO cell "does not know" if the signal is connected to QFP PinX or BGA Pin Y...
We have a tested and many years in service proven programming which should be ported to a BGA housing with better availability meanwhile.
Thus, I think a crossreference would be the way forward, like QFP PinX => BGA PinY, ...
