19 years agoIs there a way to program an epcs prom in circuit without using Nios?
I want to re-program my epcs prom in the field. I see that I can do it using a nios design but I dont want to write nios software to do it. Is there a way to just write some hdl to connect to the i...
19 years agoHere is an application note that addresses this topic.
http://www.altera.com/literature/an/an379.pdf The secret is knowing that there is a hidden atom in the FPGA that allows you to access the EPCS pins through the FPGA fabric. In a Cyclone II device for example the atom is called cycloneii_asmiblock. This block will be recognized by Quartus and compile into your design. A whole reference design exists in application note 379.
