19 years agoIs Nios II free?
Is the Nios II processor free? I have checked the Altera website but I do not quite understand what a time limited license is? Is the IDE time limited or is the processor that runs in your FPGA time limited?
Ben13 Replies
does the full nios II license covers other nios-related features like C2H compiler and MicroC/OS II as well or they need separate license?
To add to what Avatar said...
The license Avatar talks about is pretty cheap: $495 a seat. If that's too much, Altera does offer a free (as in $0) time limited license too, which you mentioned in your question. They call this "OpenCore Plus". Great for evaluating with having to pony up the 500 bucks. The way the OC+ license works is that the Nios core will run forever as long as a Blaster programming cable is connected to the board. Once the programming cable is disconnected the Nios core will time out after a certain amount of time (not sure exactly how long, I think it depends on clock speed.) - Altera_Forum
The NIOS II processor is free to the extent that once you purchase a license to compile the NIOS II code through your tools, then you do not have to pay any royalities for inclusion in any of your designs.
The NIOS II IP is delivered with the basic Altera software IP release, but until it is licensed it will only allow "teathered" usage in your designs. (Via open core plus and the JTAG cable). If you purchase it with a Kit then the license is good for one year, after which it will no longer compile. If you purchase it as a full subscription then it will compile forever, but after one year, if you do not renew your maintainance, then you cannot update to the then latest version of Altera tools (but the latest one you get just before your license expires will work perpetually). I hope this clears things up. Avatar
