lutzek
6 years agoIs M9K memory output clock recommended? (MAX 10)
Hello
I'm using MAX10 device. When internal memory block is created in MegaWizard, an output of memory is clocked by default (in both ROM and RAM memories). Is it recommended from some functional reason (is it better for application), or it is never mind if I'll go with clocked or not clocked output? Does memory output clocking have any advantage?
Thank you
1 Reply
- JohnT_Altera
I would recommend it so that your output is registered and would you will have a stable output.
