JBoot1
6 years agoIs it possible to use the FLR for the HIP PCIe AVST core to reset logic?
I have an endpoint design which uses the hard IP PCIe avalon-st core with multiple functions. One of the functions is used by a VM so I would like to enable the function level reset for that functi...
SengKok_L_Intel
6 years agoThe bits that relate to FLR are located at Device capabilities register (bit 28), and Device control register (bit 15) as per the PCIe spec.
In the Cyclone V PCIe AVST user guide, it is mapping to the PCIe Capability Structure (table 8-8), however, the FLR is not supported in Cyclone V PCIe AVST, the IP may not respond with it at all.
Regards -SK
- JBoot16 years ago
If the FLR is not supported in the Cyclone V PCIe AVST, then why are there parameter bits available in Platform Designer to enable it on a per function basis?
