14 years agoIs it possible to make a bottom level design
Hi all! I am a student and recently my professor ask me to see if it is possible to create delay lines with FPGA ( by cascading buffers or inverters together ) so that we may be able to test ch...
14 years ago --- Quote Start --- I am a student and recently my professor ask me to see if it is possible to create delay lines with FPGA ( by cascading buffers or inverters together ) so that we may be able to test chip delays with such a tool. --- Quote End --- Yes it is, but the stability of the delay might not be acceptable. The delay will be a function of the fabrication process, the supply voltage and the local die temperature. --- Quote Start --- which means that I need to modify those gates inside a FPGA directly and somehow arrange them together to generate different delays. --- Quote End --- That's correct, you will likely need to hand pick locations. --- Quote Start --- I do have experience of programming FPGA with altera tools before (writing codes in Verilog then compile them blah blah blah..). But I am very clueless about how to modify the lower level units by myself! --- Quote End --- From a code perspective you might have to write multiple assignments in order to get enough delay for whaterver your purposes are. delayed_sig(i) <= delay_sig(i-1); delayed_sig(0) <= input_sig; And then use the proper attribute to inhibit logic optimization. --- Quote Start --- so here is my question: How to modify the bottom level elements of FPGA by myself? Is there any Altera tool that allows me to do so? --- Quote End --- Quartus will allow you to specify locations. Kevin Jennings
