Is it possible to configure Agilex-F P-Tile to have a PCIe Gen4 X4 EP port and a Gen4 X4 RP port?
- 6 years ago
Thanks for the helps.
I misunderstood your words of "only assign". Actually you mean "only connect", which makes sense for me. I will try it soon, and right now I am struggling on generating the RP IP.
Xiao
Hi Xiao,
1) There is a hardware limitation in the x4 core where it does not enable for EP, this is the same for R-Tile. See table 12 below.
https://www.mouser.do/pdfDocs/ag-overview.pdf
2) The “bifurcation mux” in table 57 is supported in v20.2, there is a plan to update this document in the next release.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ptile_pcie_avmm.pdf
3) In a single P-Tile, it can only support either EP or RP. Both EP and RP are unable to configure in a single P Tile at the same time.
Regards -SK
Got it. Interested in the "4 X4" configuration shown in the Table-57, mentioned in the answer-2.
In our design, we just want to active the X4 RP port on the lane#4-7 driven by the X16 core, and to disable the X4 RP ports connected to the other lanes (lanes#0-3 and lanes#8-15). Is it doable? Especially, we want to disable the PHY on lane#0-3, when the X4 RP port on lane#4-7 is running.
Xiao
