14 years agoIs is possible to split Qsys conduits
Hi, i desinged a system in Qsys with multiple devices that have conduit interfaces. One of the devices has a conduit interface (VHDL std_logic_vector). The elements of the standard_logic_vector...
14 years agoI think you can define a custom component based on the original device.
First of all, create wrapper code which implements the division of the standard_logic_vector using the VHDL code above, while it simply connects all the other ports pin to pin. Then in the component _hw.tcl file you expose internal signals with lines like this: add_interface_port conduit_end <internal_signal> export Output 1 I'm almost sure you can do the job with a simple tcl script, without the wrapper, but I'm not very expert on this subject.
