8 years agoIs CPLD required for booting CYCLONE 5 FPGA from QSPI flash.
in cyclone 5- fpga can’t able to fetch the program from spi flash FPGA - cyclone 5 (5cgtfd7d5f27i7n) SPI FLASH - epcq128si16n in our board only one spi flash (configuration flash) is ...
8 years agoYour power up sequence looks OK. Refer to the 'Power-Up Sequence Recommendation for Cyclone V Devices' section, page 10-4, of the 'cyclone v device handbook (https://www.altera.com/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf)'. Note the comments about monotonicity and meeting the T_ramp time.
Also consider the 'Power Pin Connections' section, page 12, of the 'arria v and cyclone v design guidelines (https://www.altera.com/en_us/pdfs/literature/an/an662.pdf)'. --- Quote Start --- ...ensure that the minimum current requirement for the power-on-reset (POR) supplies is available during device power up. --- Quote End --- Are your power supplies good enough for this? Note the maximum currents required in Table 10-1: "Maximum Power Supply Current Transient and Typical Duration", in the Device Handbook. If the supplies dip at all during power up the device may not start properly. Are ALL you device's power pins connected? Do you have a schematic/symbol/footprint issue? I'm suspecting this is power related. Cheers, Alex
