13 years agoIs CONF_DONE read by the FPGA?
Hi All, I'm debugging a board with a Cyclone IV device where the CONF_DONE pin was inadvertently left floating. The FPGA configures fine over JTAG but when configuring from EPCS it reads the w...
13 years ago --- Quote Start --- Once upon a time I think there was an option to get the FPGA to ignore CONF_DONE but it doesn't seem to be there anymore in 12.1SP1. --- Quote End --- Its still there. File->Convert Programming File, Click on the Advanced options. There's a check-button there that says "Disable AS mode CONF_DONE error check". Though I suspect that applies to AS programming with a JTAG cable, rather than with an EPCS device, since the EPCS device cannot check CONF_DONE ... but then again, perhaps the FPGA does an internal check of CONF_DONE. Report back on whether it made a difference. Cheers, Dave
